Power Supply - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: Power Supply
    Points: 21, Level: 1
    Level completed: 41%, Points required for next Level: 29
    Travellingman is on a distinguished road
    Dec 2012
    Power Supply
    I have an original Galaxy Tab that has a 5v 2amp power supply. In addition I have an S3 and a Galaxy Y Duos both of which are supplied with 5v 1amp power supplies. You can charge the Tab with a 1 amp supply but it takes for ever. I don't want to cart upteen power supplies around so the question is, is the 2 amp supply usable on the S3 / Y Duos or will the extra amp screw up the phone / battery?
    greenman has a brilliant futuregreenman has a brilliant futuregreenman has a brilliant futuregreenman has a brilliant futuregreenman has a brilliant futuregreenman has a brilliant futuregreenman has a brilliant futuregreenman has a brilliant futuregreenman has a brilliant futuregreenman has a brilliant futuregreenman has a brilliant future greenman's Avatar
    No, the device will take as much ampage as it needs.
    The problem, as you have found out, is the other way round. Where the max amp is too low then not enough power is provided.
    Dec 2012
    Many thanks Greenman, just saved me a pile of power packs to lug around........dml
