Fullscreen on Flash? - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: Fullscreen on Flash?
    Points: 19, Level: 1
    Level completed: 37%, Points required for next Level: 31
    Nov 2012
    When I used to use flash games on the web browser on Android, I was able to hold my finger down till the option to make the player fullscreen appeared in the corner. Since updating to the latest version of Android, that function seems to be gone. Is there any way of getting this back?
    Points: 67,446, Level: 100
    If you are running Jelly Bean, flash is not supported and whilst it will still work some of the functions are limited, so short answer is probably, No.....
    Hmmm.....breaking promises here
    http://www.androidauthority.com/run-...evices-103263/
    Edit: Still restrictions may apply???
    TBH I've only tried it on the stock browser. Chrome won't see it but Dolphin is supposed to play nicely with flash. I can't get the double tap to full screen that I used to get on ICS but that is the only feature that I've found not to work so far......
