won't ring? - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: won't ring?
    Points: 1,667, Level: 16
    Level completed: 59%, Points required for next Level: 83
    7 days registered31 days registeredTagger Second Class100 Experience Points3 months registered
    Aug 2012
    Cool won't ring?
    MY Slll phone rings allright but it wont ring on TEXT it just come up with a call icon ,what can it be?
    Points: 67,443, Level: 100
    Can you post some screen shots ?
    Aug 2012
    My wifes got it i won't have it until tonite (You were quick)
    .....or lucky
    It sounds a strange problem - Just want to be sure I am understanding it correctly......?
    Aug 2012
    Hi yes the phone rings when you get a call,that's ok, but when you get a TEXT msg you don't hear anything but the icon comes up on the screen and you don't know unless you look at it and that could be hours.
    Is it the correct TEXT notification that you get on screen or a missed call symbol....?
    First check is to make sure you have text notification sound set to on.
    Aug 2012
    Yes text not... is on sorry ITS NOT on .....now it is and it is working fine thank you
  11. Remove Advertisements
