Hydro gel Skin Cover Case, review. - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Results 1 to 9 of 9
Thread: Hydro gel Skin Cover Case, review.
    Points: 20,686, Level: 62
    Level completed: 75%, Points required for next Level: 164
    Overall activity: 99.7%
    This a small review on the Hydro gel Skin Cover Case.
    This wasn't taken by me, but is how it looks like.
    Cost: under £3. ebay.
    When I first got this case I was a little disappointed because I thought it would be a bit softer like the one I bought for my I8910 awhile ago.
    Apart form my prejudged disappointment, this case is good.
    It fits the Galaxy S like a glove, with the cut outs all in the right places, except the volume and lock buttons.
    Its semi see-through and has a good gripy feel in the hand so it won't slip out. If you have really greasy, sweaty hands you may not like this case as it's abit like soft bendy plastic in feel.
    The case it self only adds a couple of mm's to the phone and seems soft enough to stop damage to the phone if dropped (I've not tested it yet).
    It covers all the phone apart from the front face, (it ends after covering the metal bit) leaving no obstruction to the touch screen or buttons.
    The bad bit: Because it covers the volume and lock buttons, you require abit more force to use them especially the lock button, as there nearly flush with the rest of the case.
    For me this is a great buy,
    It doesn't really add any bulk,
    Easy to remove in/out of pockets,
    Feels secure,
    It's a tight fit so the phone doesn't move around and is easy to remove when needed.
    This is great for every day use and if you don't want a leather case or like me on a small budget.
    Will take some photo's when I get my other phone back if others are interested.
    Senior Member systemX is a jewel in the rough systemX is a jewel in the rough systemX is a jewel in the rough
    thanks for the review Doomed.
    Got the same kind (Or at leased a bit like it) of case, for the S3. So far so good.
    Although I cut out holes for the power and volume buttons (That's more for me than, hard to press).
    I got a white case, which has started to get a some marks on it. They haven't come off with my rubbing finger so maybe it's time for a damp cloth
    Points: 126, Level: 2
    Level completed: 52%, Points required for next Level: 24
    Overall activity: 46.0%
    7 days registeredTagger Second Class31 days registered100 Experience Points
    Selenagomes is on a distinguished road
    Ordered this for my new Samsung Galaxy Ace phone and was not disappointed. Fits easily but snugly and looks as if it should be part of the phone. Nice grooved areas at the side to assist with grip.
    Yes just add to the spam in this thread, like every one else.
    Points: 406, Level: 7
    Level completed: 6%, Points required for next Level: 94
    Overall activity: 16.0%
    alicepattinson is on a distinguished road
    Feb 2013
    I also have this type of case but only a pink one though
    I don't have that case any more, or the phone to go with it But the case I have not is not much different, it was white but now it's um
    Points: 371, Level: 6
    Level completed: 72%, Points required for next Level: 29
    andrewlo is on a distinguished road
    Sep 2012
    Image deleted as it contained Advertising
    I also got a similar case for my S3. It is plain and without any designs. However, it is slim and protective as well.
    Points: 53,660, Level: 100
    Quote Originally Posted by andrewlo View Post
    I have edited your post as it contained advertising. If you wish to post the picture again please make sure it does not contain a website address.
    S3 (i9300) as Stock as it gets
    G+ Tuffinhio Mamoru
    Twitter @Tuffinhio
    Instagram - Tuffinhio
  11. Remove Advertisements
