firmware help - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: firmware help
    Points: 932, Level: 11
    Level completed: 88%, Points required for next Level: 18
    Overall activity: 10.0%
    Tagger Second Class7 days registered100 Experience Points31 days registered3 months registered
    misfit is on a distinguished road
    gloucester
    firmware help
    hi all, my s2 is stuck in download mode, am trying to flash a stock firmware in odin but odin is stuck on <ID:0/004> cache.img
    any ideas or help ?
    Pull plug and start again.
    Is your phone unlocked to any network (sim free)
    Did you select USB debugging mode?
    Did the ID:COM box go yellow?
    Are you using original USB lead as supplied?
    If Kies is running, stop it.
    gloucester
    tried all the above, not turning on at all now so sending it back
    Points: 38,846, Level: 86
    Level completed: 61%, Points required for next Level: 354
    What version of Odin are you using...?
    Do you have the PIT file selected?
