MMS viewed as slide show...help - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: MMS viewed as slide show...help
    Points: 21, Level: 1
    Level completed: 41%, Points required for next Level: 29
    tanlh is on a distinguished road
    Aug 2012
    Unhappy MMS viewed as slide show...help
    hey guys,
    I don't know why but all my mms' are showing as slide shows. when I try to view ones that I've sent or received, they always play as a slide show. how can I turn this feature off?
    Also, when my friend sends me an mms from her iphone I can only view it as a slide show. I then download the attachment to my SD card and when I go to the file to view it, the picture has all these yellow squares on it. Is there any way I can remove these squares? I just want to view the pic in full screen mode
    thanks.
    Points: 38,781, Level: 86
    Level completed: 54%, Points required for next Level: 419
    Don't know what an iphone does to pictures so I can't help, but MMS are displayed in the way you describe. Always have been and I guess always will be. The theory is, if someone sends you more than one picture they are displayed in turn.....
