[SGS II] how to open and view caches - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: how to open and view caches
    Points: 28, Level: 1
    Level completed: 56%, Points required for next Level: 22
    saraholmes is on a distinguished road
    Aug 2012
    I found the caches under my files but it won't let me open them on my phone. I also tried connecting my phone to the computer with the usb chord and opening from my pc but some won't open. How do i view them?
    Points: 53,380, Level: 100
    Hello, what caches are you on about? The cache folder which you are talking about may have been placed there by an app which none of us use. I do not have a cache folder in My Files.
    Are these cached files from an app like Draw Something, the internet?
    Do the files have extentions like .exe/.html? You could google the extentions to see what they are and which program will best view them.
    Aug 2012
    well it wasn't just in my files but once i opened up hidden files and went on my computer there was the android file and under there were some other files and one name was something like hireimages and it had caches to it. i do not remember the extensions and don't have the phone on me right now to check. but in general there are just a lot of caches on the phone i would like to look at
    I think your best option is to check Google or Wiki for file extensions, even XDA forums may have some information for you. If you get really stuck just post some of the directory structure and file names and see if anyone can help.
    Aug 2012
    okay will do and thank you for the help!
