HELP: Galaxy S2 Won't Turn On - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: HELP: Galaxy S2 Won't Turn On
    Points: 18, Level: 1
    Level completed: 35%, Points required for next Level: 32
    mzkiyo is on a distinguished road
    Aug 2012
    Unhappy HELP: Galaxy S2 Won't Turn On
    The phone was unplugged it from the computer and it stopped turning on since it's been interrupted it while it was installing new software. Anyone know what the problem is and/or if this is an easy fix?
    Thanks a bunch.
    Points: 38,631, Level: 86
    Level completed: 37%, Points required for next Level: 569
    Check if you can get into download mode. Take out battery, put back in, then hold Vol down + Home + Power buttons all together. If you can get into download mode you can flash new firmware with Odin.....
