Sd Card not available. Not mount SD card - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: Sd Card not available. Not mount SD card
    Points: 29, Level: 1
    Level completed: 58%, Points required for next Level: 21
    huble is on a distinguished road
    Aug 2012
    Smile Sd Card not available. Not mount SD card
    My Galaxy S not reconizes the SD card.
    I try to format but only says that will erase the data.
    I test with a working sd but the same problem remain.
    Any suggestion?
    Points: 20,945, Level: 63
    Level completed: 15%, Points required for next Level: 555
    Can you explain why you think the micro SD (I believe your referring too) is unable to mount.
    Try this. Using a file explorer (Like my files) Look for a file called extSdCard, Or something like this. Mite also be called emmc. Then try adding a file. This is your External SD card (Micro SD).
    Or have I completely missed
    Aug 2012
    Quote Originally Posted by Doomed View Post
    The SD external and SD internal are not recognized. So there is no space where install any new program. Even a phote can take 'cause there is no space available.
    I suppose the phone must work without an external SD. But intarnal space is not reconized either.
    Points: 39,916, Level: 87
    Level completed: 80%, Points required for next Level: 184
    I think you have been messing about with either firmware or root directories. I suggest you reflash with stock firmware.
    Points: 17, Level: 1
    Level completed: 33%, Points required for next Level: 33
    Overall activity: 3.0%
    nadz is on a distinguished road
    Oct 2012
    Hi , I got Samsung GAlaxy S thats has been playing up lately that's why I moved all my photos and musics to sd card. The problem is I can't find all the data on the sd card. What should I do? I cant find the pictures of my baby since the day she just born until recently.. ='(
    Have you got a file manager on your phone?
    Take a look at Astra: https://play.google.com/store/apps/d...go.astro&hl=en
    Once you've found them it would be a good idea to backup to your computer and a cloud storage.
    I find dropbox very good and photo's on your phone are automatically uploaded once you've set it up.
    https://play.google.com/store/apps/d....android&hl=en
