[SGS II Rom] Firmware I9100XWLPT 4.0.4 for Samsung Galaxy I9100 - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: Firmware I9100XWLPT 4.0.4 for Samsung Galaxy I9100
    Points: 20,347, Level: 62
    Level completed: 23%, Points required for next Level: 503
    BarosanuXXL is a jewel in the rough BarosanuXXL is a jewel in the rough BarosanuXXL is a jewel in the rough BarosanuXXL is a jewel in the rough
    Base Firmware: I9100XWLPT(4.0.4)
    Modem: I9100XXLQ6
    Build Date: 27-07-2012
    Changlist: 941023
    Instructions For Flashing:
    [*]Extract the firmware[*]Open the included Odin[*]Put your device into Download MODE (Home + Volume Down + Power)[*]Click PDA and select *.tar.md5[*]Then finally click START!
    Code:
    # begin build properties
    # autogenerated by buildinfo.sh
    ro.build.id=IMM76D
    ro.build.display.id=IMM76D.XWLPT
    ro.build.version.incremental=XWLPT
    ro.build.version.sdk=15
    ro.build.version.codename=REL
    ro.build.version.release=4.0.4
    ro.build.date=Fri Jul 27 17:41:49 KST 2012
    ro.build.date.utc=1343378509
    ro.build.type=user
    ro.build.user=dpi
    ro.build.host=DELL169
    ro.build.tags=release-keys
    ro.product.model=GT-I9100
    ro.product.brand=samsung
    ro.product.name=GT-I9100
    ro.product.device=GT-I9100
    ro.product.board=smdk4210
    ro.product.cpu.abi=armeabi-v7a
    ro.product.cpu.abi2=armeabi
    ro.product.manufacturer=samsung
    ro.product.locale.language=en
    ro.product.locale.region=US
    ro.wifi.channels=
    ro.board.platform=exynos4
    # ro.build.product is obsolete; use ro.product.device
    ro.build.product=GT-I9100
    ro.tether.denied=false
    # Do not try to p**** ro.build.description or .fingerprint
    ro.build.description=GT-I9100-user 4.0.4 IMM76D XWLPT release-keys
    ro.build.fingerprint=samsung/GT-I9100/GT-I9100:4.0.4/IMM76D/XWLPT:user/release-keys
    ro.build.characteristics=phone
    # Samsung Specific Properties
    ro.build.PDA=I9100XWLPT
    ro.build.hidden_ver=I9100XWLPT
    ro.build.changelist=941023
    # end build properties
    Download:
    CSC: I9100CPWLPA
    Download from Directmirror.com
    Download from Uploads.ws
    CSC: I9100XEULPA
    ODIN + PIT + Flashguide |Download
    Source
  2. The Following User Says Thank You to BarosanuXXL For This Useful Post:
    bubblehead (08-03-2012)
  3. Remove Advertisements
    Infant Member
    Points: 11,672, Level: 46
    Level completed: 75%, Points required for next Level: 128
    Overall activity: 96.0%
    stonkr is a splendid one to behold stonkr is a splendid one to behold stonkr is a splendid one to behold stonkr is a splendid one to behold stonkr is a splendid one to behold stonkr is a splendid one to behold stonkr is a splendid one to behold stonkr is a splendid one to behold stonkr's Avatar
    The Ice Kingdom
    Today I flashed LPT from sammobile.com onto Mrs stonkr's SII and used LQ5 CF-Root as Chainfire is away until mid August so there's currently no LPT CF-Root. Works perfectly although I see not all of the 4.0.4 features on my SGSIII are in the LPT firmware.
    I also used UOT Kitchen for the first time as I like the circular battery mod and was finding it increasingly difficult to find one to download. I thought I'd post the procedure here as it took a few attempts to get it right. I confirm UOT works with ICS but I understand only for the battery mod.
    1. Install your firmware and root of choice onto your phone.
    2. Using your favourite file manager that has root access, copy framework-res.apk from /system/framework and SystemUI.apk from /system/app to somewhere accessible, like the root of your sdcard, then move those files to your computer.
    3. Start the UOT Kitchen website.
    4. In the 'Battery' tab choose which battery mod you want, I went for one in the 'SCB with %' list.
    5. In the 'File upload' tab, under 'Select flashable zip scripting' select 'Type EMMC' in the 'update-binary' drop-down box. The update zip will NOT work otherwise.
    6. Select the 'upload system files' radio button and upload your framework-res.apk and SystemUI.apk files.
    7. In the 'summary' tab select 'Submit work to kitchen'. Go to the collection screen using the link. Wait for your mod to be cooked...
    8. Copy the zip file to somewhere on your phone, you can rename it to something more recognisable.
    9. Boot into recovery and install the zip.
    That's it. Job done.
    EDIT: Managed to put it in safe mode when putting it back in it's Casemate Tough. A reboot didn't work. Pulling the battery for a minute did. I understand you activate safe mode by pressing the menu button when booting. Didn't even know it had a safe mode.
  5. The Following User Says Thank You to stonkr For This Useful Post:
  6. #3
    Points: 1,369, Level: 14
    Level completed: 80%, Points required for next Level: 31
    kathard is on a distinguished road
    I do hope Chainfire will produce a CF-Root for I9100XWLPT(4.0.4). I updated to 4.0.4 with KIES and lost CF-Root from 4.0.3. Presumably I will be able to re-root with the CF-Root when Chainfire makes it. I lost Titanium PRO and SuperSU.
