ring sound and text sound - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Results 1 to 10 of 17
Thread: ring sound and text sound
    Points: 2,213, Level: 19
    Level completed: 32%, Points required for next Level: 137
    mrcj is on a distinguished road
    Exclamation ring sound and text sound
    Sorry if this has been ask before.
    I have got the samsung galaxy s3 had to take it back once and now on my second one, but I am having the same problem as the first.
    Every now and then when I receive a call or text message it will just vibrate or no sound. I checked my settings and they are all correct for sound. Am I the only one having this problem or is it a known problem. How can I fix it. I have missed a number of calls and text because of this.
    MrCj
    Points: 9,791, Level: 42
    Level completed: 65%, Points required for next Level: 159
    Overall activity: 37.0%
    Tagger Second Class7 days registered100 Experience Points250 Experience PointsTagger First Class
    Swipermusic is just really nice Swipermusic is just really nice Swipermusic is just really nice Swipermusic is just really nice Swipermusic's Avatar
    Solihull
    Never heard of this before and on two phones? Are you sure your volume rocker isnt too low or set to silent. Put the volume up to max, set the individual tones for ringtone and notifications, make sure silent mode at the top is off.
    SGSIII
    Unlocked
    O2 Rooted
    Check all that they all as you say. It also the tones when touch screen stop found only way to sort it is to lock phone and unlock it.
    MrCj
    Points: 16, Level: 1
    Level completed: 31%, Points required for next Level: 34
    jyotsana is on a distinguished road
    Hi
    In Samsung galaxy s plus i9001 , application is getting closed suddenly and very frequently and also its blinking when it is kept idle .
    please suggest some solution.
    Thanks in advance .
    Jyotsana
    Points: 4,277, Level: 27
    Level completed: 59%, Points required for next Level: 123
    Overall activity: 25.0%
    Tagger Second ClassTagger First Class7 days registered100 Experience Points250 Experience Points
    Jejoma will become famous soon enough Jejoma's Avatar
    EU but not EU
    Whilst it won't solve your problem, using Quicker might give you a clue as to what is going on. It's actually a utility for quick access to the various settings. One of the options is to micro-manage the sound settings individually. You might be able to use it to see whether they are actually being reset and if so which are being changed.
    As I said, not a solution but it might spread some light.
    Ok What is Quicker??
    MrCj
    Points: 53,526, Level: 100
    The internet is a handy thing, go into Google and type 'Quicker for Android'.
    Edit: Plus Jejoma explained what it does and you'll find out quicker rather than waiting for someone to post it.
    Ok thanks to all
    MrCj
    This is starting to be the worse phone I have ever had. I cant be the only person who is having this problem, cos I had it happen on 2 phones, now the only why that i can sort it out is to restart the phone.
    MrCj
    Points: 38,752, Level: 86
    Level completed: 51%, Points required for next Level: 448
    Maybe its an app that you are installing......?
