phone going into airplane mode - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: phone going into airplane mode
    Points: 3,637, Level: 25
    Level completed: 35%, Points required for next Level: 163
    Tagger Second Class100 Experience PointsTagger First Class7 days registered250 Experience Points
    LisaUK is on a distinguished road LisaUK's Avatar
    when I set my phones alarm clock at night, the phone has recently started going into airplane mode of its own accord. This isn't affecting the alarm but obviously I am missing any texts or phonecalls coming through and don't get them until I wake and change the phone mode back. I am running ICS 4.0.3 LPS rooted using Chainfires kernel.
    Any ideas would be appreciated, Lisa
    If voting could change anything it would be illegal.
    Points: 38,702, Level: 86
    Level completed: 45%, Points required for next Level: 498
    How strange.... Do you have power saving apps or anything like "automatit" installed?
    What happens if you put the phone back out of flight mode? Does it do it immediately after you set alarm or after a while? Can you set a recurring alarm so you don't have to set it every day?
  4. The Following User Says Thank You to RichH For This Useful Post:
    LisaUK (07-20-2012)
  5. #3
    I found the problem buried in some settings in an app I was using. It's called 'SleepBot' and measures how much sleep you're getting and when I was used it the other day I found the app switching flight mode on, so I checked through the settings and it was a setting in there. All sorted now. Thank you!
