[SGS II] battery drain? screen turning on? charging when unplugged? other bizarre behaviour? - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: battery drain? screen turning on? charging when unplugged? other bizarre behaviour?
    Points: 1,080, Level: 12
    Level completed: 87%, Points required for next Level: 20
    Overall activity: 10.0%
    Tagger Second Class7 days registered100 Experience Points250 Experience Points3 months registered
    sungod is on a distinguished road
    here
    for a few weeks my, c. 14 month old, sgs2 has been acting strangely...
    some days, the battery drains in just a few hours
    sometimes saying charging when disconnected from charger, then saying it's stopped charging due to high voltage
    the screen turning on every 3-4 minutes when charging
    voice input screen popping up even though it's turned off
    the clock/weather screen randomly appearing
    and other weirdness
    ...it does *none* of these consistently, some days are fine, others two or three of the above might happen, no apparent pattern
    i tried...
    deleting/disabling various apps
    rebooting
    different cable
    different charger
    clearing data
    deleting/adding accounts
    turning off wifi
    factory reset
    etc. etc.
    today i fixed it, i changed this part...
    http://www.amazon.co.uk/Connector-Ch.../dp/B005X7EVU0
    bliss
    sometimes, just sometimes, it's not the software
    Points: 38,740, Level: 86
    Level completed: 49%, Points required for next Level: 460
    I've changed a few of these myself and mentioned it many times on here, but some people don't want to hear it and try to convince themselves its a software issue......
