[SGS II] Microphone- dodgy when recording video and none in speakerphone mode - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: Microphone- dodgy when recording video and none in speakerphone mode
    Points: 205, Level: 4
    Level completed: 10%, Points required for next Level: 45
    Tagger Second Class7 days registered31 days registered100 Experience PointsTagger First Class
    pitrack_1 is on a distinguished road
    ACT, Australia
    My wife's SGSII (GT-I9100T) is not recording proper sound in video mode (scratching/static noises from the top mic with other input from the bottom mic) and in speakerphone the mic doesn't seem to be working (other end can't hear you). The speaker itself works fine, so does normal handset mode.
    I believe that both video and speakerphone use the top mounted mic (next to the headphone jack), speakerphone using it exclusively- hence no sound transmitted.
    This phone has been immersed, I've 'rescued' it although I had to sacrifice a shorting chip- power chip for the USB OTG (see my other thread here), although I don't believe this is related.
    It's possible the immersion has damaged the mic. unit too, if so where can I buy one at reasonable price? I'm located in Australia so they'll have to ship out to Aust at a reasonable rate. From the SGSII service manual The unit I'd need seems to be part "QAR01 MODULE-RCV+MOT+MIC+E/JACK FPCB(GT_I9100) GH59-10935A"
    A search for GH59-10935A on ebay.com.au returned nothing, there are a few odd shops elsewhere. Any ideas, and anywhere good to order parts from? Note again it's a GT-I9100T although I suspect it will make no difference for this component area.
    Thanks,
    Pitrack_1
    Pitrack_1
    Points: 38,846, Level: 86
    Level completed: 61%, Points required for next Level: 354
    Before I got to the "Immersion" bit I was gonna suggest water or impact damage.... If a trawl of Ebay (inc ebay.com) does nothing, you could try amazon......
