[SGS II] Samsung Galaxy SII is not charging - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Results 1 to 10 of 13
Thread: Samsung Galaxy SII is not charging
    Points: 46, Level: 1
    Level completed: 92%, Points required for next Level: 4
    Overall activity: 16.0%
    My Samsung Galaxy SII ran out of charge and when I plug in the charger it is not charging. I changed the charger but still not charged. Would you please help me with this problem.
    Tahir
    Points: 66,971, Level: 100
    Take out battery, hold power button for 30 secs, replace battery and charge again.
    Thanks. I did the same as you advised and it is still not charging.
    The screen is off. It does not show charging not anything else.
    It is possible that you have some debris in your usb socket. Try a clean, preferably with compressed air but a gentle probe with a toothbrush may help (use your partners LOL)
    It may be that the pins inside your socket have been bent so check for that.
    The usb socket can be replaced fairly easily (DIY) Look on Ebay for a replacement.
    Thanks. let's say the phone is completely dead. I replaced the battery with a charded one. But still not working.
    Can you get into recovery mode? Hold vol up + home + power key. If recovery mode boots, try a factory reset.
    Thanks. I did the recovery and it does not boot.
  10. The Following User Says Thank You to tkhan33 For This Useful Post:
    AdamGessler (01-28-2016)
    Same keys again but hold vol down instead. If this takes you into download mode you could try reflashing firmware, but I think you need to send it in for repair as it sounds stuffed.
    Points: 13, Level: 1
    Level completed: 25%, Points required for next Level: 37
    Oct 2012
    same thing happening to me.mobile not charging, showing a yellow sign. i tried all wat was said in the comments previously but still nothing.
    can someone please help.
