Tutorial: How to debrand and flash newer firmware to your Galaxy S - Samsung Galaxy S Forums : Galaxy S2 S II Forum - Page 4
Page 4 of 14 FirstFirst ... 2 3 4 5 6 ... LastLast
Results 31 to 40 of 134
Thread: Tutorial: How to debrand and flash newer firmware to your Galaxy S
  1. #31
    Points: 1,036, Level: 12
    Level completed: 58%, Points required for next Level: 64
    Gaf is on a distinguished road
    im assuming this will work on windows 7 32 bit as well
    Common sense aint common anymore
    oh has anyone tried to flash a phone that is locked to a network... on the guide it says make sure your phone is sim UNLOCKED
  4. #33
    Points: 2,898, Level: 22
    Level completed: 40%, Points required for next Level: 152
    Overall activity: 10.0%
    100 Experience Points7 days registeredTagger Second Class250 Experience Points500 Experience Points
    aciduzzo will become famous soon enough
    the XWJG5 download doesn't have a .pit file. Is this needed?
    edit: i noticed there's a .pit file in the Odin download.
  5. #34
    from Briggs' earlier post, it appears this should only take a minute or so. however, i've tried a couple of times and even after 20 or so mins, nothing much seems to happen. as i speak i have the following:
    <ID:0/011> Added!!
    <ID:0/011> Odin v.3 engine (ID:11)..
    <ID:0/011> File analysis..
    It's running on Com 11 this time (previously COM 10) but i doubt that should matter. Anyway got any tips?
  6. #35
    fake Mọderator
    Points: 31,311, Level: 77
    Teh USA
    if it doesnt happen after 5 seconds its not gonna happen. do it again, but this time add in the CSC file that came with it
    .____________...___________./l、
    ...add me [= .......____________...(゚、 。 7
    .......h3artlessjerk@hotmail.com .  l、 ~ヽ
    .............._______________............... じしf_, )ノ
  7. #36
    thanks soraxd, that's exactly what i just tried and it has worked. for anyone else below are the commands you should get. the important part was adding the CSC file.
    <ID:0/009> Firmware update start..
    <ID:0/009> factoryfs.rfs
    <ID:0/009> cache.rfs
    <ID:0/009> dbdata.rfs
    <ID:0/009> boot.bin
    <ID:0/009> Sbl.bin
    <ID:0/009> param.lfs
    <ID:0/009> zImage
    <ID:0/009> Removed!!
  8. #37
    Mine shows up as COM5, is that ok?
  9. #38
    fake Mọderator
    Teh USA
    yeah, i got COM6 and COM4 on two diff comps, its cool
  10. #39
    Just flashed to XJF5 but under firmware it displays the old one i flashed from (XJF3) :S
    also this one doesnt have the voice google search bar on home...
    not sure if that can be added/downloaded but and help would be very much appreciated
  11. #40
    Decided to flash to JG5. Under firmware the build number is JG5 but the Baseband is still JF3...
    Is that normal?
There are currently 2 users browsing this thread. (0 members and 2 guests)
