HELP!! Phone wont boot up!! - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: HELP!! Phone wont boot up!!
    Points: 2,250, Level: 19
    Level completed: 50%, Points required for next Level: 100
    Stockton on tees
    i have galaxy s 3 and well my phone wont boot up at all! I get to the samsung galaxy s3 splash screen and thats it! i can access download mode but thats all it wont let me access the reboot mode (up vol + menu key + powaer key). any sugestions??
    Sounds like a conflict of some kind.
    Have you installed new firmware recently?
    Try removing external sd card if you have one, and reboot.
    You can re flash your firmware with Odin if still a problem, but may be easier to return under warranty.
  4. The Following User Says Thank You to greenman For This Useful Post:
    Acid2000 (07-05-2012)
  5. #3
    Stockton on tees
    all i have done with this phone is root it and that is it! i was going to reinstall firmware but i have not changed much other rooting could it be this that caused it? alternative i was going to warrenty it as i only had a week! is there any debranded firmware for it?. im on orange 4.04 not sure of csc ect cause cant access it
    Rooting may well have caused the problem.
    To debrand you need to unlock first, and don't know of a free method.
    Safest thing to do is to reflash with Orange firmware. This will remove root.
  8. #5
    Stockton on tees
    any idea which software is the orange Firmware??? cant seem to see it on samfimwares
  9. #6
    Points: 67,549, Level: 100
    Rooting voided your warranty anyways so you need to reflash. If the phone was locked to Orange you need the Orange FW otherwise open european will be fine.....
  10. #7
  11. #8
    Stockton on tees
    lol! i work for orange so there is no issues with warrenty! i looked on samfimwares but could not see orange firmware, so open eu firmware ill check for that.
  12. #9
    Stockton on tees
    @Greenman how you find that i look everywhere!! lol
  13. #10
    Stockton on tees
    ah forgot to click europe at right i been a dummy!
  14. Remove Advertisements
