Antenna problem, can I fix this? - Samsung Galaxy S Forums : Galaxy S2 S II Forum - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 21 to 21 of 21
Thread: Antenna problem, can I fix this?
  1. #21
    Quote Originally Posted by Jynto View Post
    Before factory reset, I finally decided to check the signal status. It says it's at -103 dBm (yes, minus) and 5 asu. Is that especially low?
    You are looking for bigger the better.
    Remembering that dBm is negative, around -60 is said to be optimum.
    With 5 signal bars and H+ I'm on -89 dBm at moment and 12 asu.
