I am a new beginner of android. I am trying connect a Creative USB web camera to my Samsung galaxy s2 mobile (GT-I9100) on Android ICS Build. So i downloaded the image I9100XXLP6_I9100OXXLP3_OXX and flashed my galaxy s2 mobile using odin 1.85 software. now my Galaxy s2 works fine with ICS build (kernel version - 3.0.15-I9100XXLP6-CP72050se.infra@SEP-53 #3, Ardroid version - 4.0.3).
Now i downloaded the samsung galaxy s2 source code GT-I9100_ICS_Opensource_Update4.zip from opensoure.samsung.com and cross compiler arm-eabi-4.4.3. Now i tried to do the make menuconfig to add the V4L, UVC and GSPCA drivers and given the make command to get the zimage <custom ICS kernel>. I got the custom zimage <kernel> of size 4.2MB size. flashed my Galaxy s2 with the my custom zimage using odin 1.85 software. Now Galaxy s2 boots with a kernel panic upload mode screen and galaxy s2 doesn't work.
So after goggling some forums i can across the initramfs <file system root> addition to the zimage. so i downloaded the Entropy512-initramfs_galaxys2_ics-0f388dc.zip, mozilla-b2g-initramfs-galaxy-s2-ics-11e8650, kgp700-exyroid-sgs2-ics-433a9c0 to build the initramfs.cpio using the command find . | cpio -H newc -o > ../initramfs.cpio and placed the the initramfs.cpio in the path /GT-I9100/usr folder and added the path in .config file and given the make command to build the zimage. now the zimage size is ~ 7.1 MB size. Again i flashed the zimage to galaxy s2, now Galaxy S2 mobile shows the kernel pain upload mode screen.
Now i am stuck up with bringing up the custom ICS kernel, So please help me to fix this issue and bring up the galaxy s2 mobile working with ICS custom Kernal image, so that i can try to connect my webcam.
Thanks,
Praveen
