How to Connect to Kies via wifi - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: How to Connect to Kies via wifi
    Points: 5,024, Level: 30
    Level completed: 8%, Points required for next Level: 276
    Tagger Second Class100 Experience Points7 days registered31 days registered250 Experience Points
    has anyone got a better guide that the one in kies? im having no luck getting it to work,
    Windows or Mac and XP or Windows 7?
    XP usually works OK windows 7 is a problem.
    Many on here will tell you not to use Kies, but what are you trying to do?
    EDIT: Sorry, you mean Kies Air
    Try Airdroid app from Playstore
    Its not kies air, but i am using windows 7, what other program works with the s3?
    What do you want to do as there is an app in the Play Store to do most of what Kies does, and usually better.
    The first problem usually with Kies is getting the drivers installed for your computer to recognise the phone.
    You can install without Kies here: http://uploaded.to/file/xeczx9xt
    Now you have the drivers, start Kies and connect your phone via USB lead provided.
    If still no joy try putting your computer into XP mode?
    i can connect via usb, just not via Wifi, i just want to manage files and stuff...
    Whats the other app's name?
    Points: 67,662, Level: 100
    Kies Air or Airdroid for wifi...
  11. Remove Advertisements
