Auto Correct / Dictionary For Texting/E-Mailing on S3 - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Results 1 to 7 of 7
Thread: Auto Correct / Dictionary For Texting/E-Mailing on S3
    Points: 44, Level: 1
    Level completed: 88%, Points required for next Level: 6
    markmclean1984 is on a distinguished road
    Hi Guys
    I have recently gotten my Galaxy S3 but cannot work out how to turn on auto correct/dictionary when using text or E-Mail?
    Any help would be great
    Thanks in advance guys
    Mark
    Have an S2 but guess it's similar.
    Go to Menu > Settings > Language and input > Keyboard and input methods and there is an icon to right of Samsung IME or your chosen input method.
    Settings are in there.
    BTW In the Play Store, SwiftKeyX is currently half price. I think it's much better than stock, especially if you are like me and have dyslexic fingers.
    Hi Dude
    Thanks very much for the advice. I followed your instructions, but there is nothing there regarding the dictionary or auto correct/spell check?
    Do you have any other suggestions?
    2 more things: 1) What is the difference between SwiftKey 3 free version and the paid for version? Do these keyboards come with spell check etc?
    Thanks once again
    Mark
    Re: SwiftKeyX, the difference is probably advertising on the free.
    SwiftKeyX learns from your typing style and offers the next word in anticipation. I find it very accurate and therefore your typing is often reduced to a one tap for a word.
    If what you are looking for is not in Settings go into the app and press Menu and select settings to see if there.
  6. The Following User Says Thank You to greenman For This Useful Post:
    markmclean1984 (06-22-2012)
    BTW I'm surprised that the predict mode XT9 is not available, and if selected there is an XT9 advanced setting where spell check can be activated.
  8. The Following User Says Thank You to greenman For This Useful Post:
  9. #6
    Points: 3,498, Level: 24
    Level completed: 80%, Points required for next Level: 52
    CarlB will become famous soon enough CarlB will become famous soon enough CarlB's Avatar
    Walsall,England
    The swipe app on the S3 is a bit of a let down.. a better option is to download Swype apk and install it... easy and doesn't require root or any hocus pocus.. it's very familiar if you've had the S or S2 and works a treat on the 3..get it from here ..http://db.tt/bymnGD93
    Carl.
    Galaxy S, AOKP port 4.03 ICS
    Galaxy S2.... Alliance Rom
    Galaxy S3 ...Stock
  10. #7
    I recommend swiftkey x as well, fantastic app and just been updated to v3, I got it on offer for 10p a while back.
  11. Remove Advertisements
