[SGS II] Otg cable with xbox 360 pad, no power! - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: Otg cable with xbox 360 pad, no power!
    Points: 878, Level: 11
    Level completed: 52%, Points required for next Level: 72
    Overall activity: 8.0%
    7 days registered31 days registered3 months registered1 year registeredTagger Second Class
    aster56 is on a distinguished road
    Exclamation Otg cable with xbox 360 pad, no power!
    Hi ive been looking at things you can do with the otg cable for galasy s 2 an dam it looks cool. so i got myself a cable 2 acctualy cuz they werent very expensive 1 from amazon an 1 from ebay 2 different cables. it works when i connect a usb flash driver to it totaly fine no problems at all.
    so i tried my usb mouse/kb, but no luck after a little bit of research i found out that some kb/mouse dont work if they need power so i moved on from that.
    then i watched some videos an read some threads about using an xbox 360 wired pad but i have the same problem, the lights flash once an then dont come back on an acts like its not powered ive seen others use same pads online an they work fine but not for me.
    is there anyone who can help me with this? im using stock rom on my s2 no changes at all no root.
    thanks hope someone can enlighten me with whats wrong.
    ps my cables do work usb storage is proff an pad is perfectly fine as i use 2 pads on xbox an work fine.
    Points: 53,113, Level: 100
    Overall activity: 83.0%
    Thank you for the post, but thats for a blue tooth conection, i ony ask for help with xbox cuz i dont own a ps3 controlller. but thanks alot for taking the time to try an help.
    cants anybody help with this? i just dont understand how my usb mem stick can work but my xbox pad cant?
