Very unusual problems with my beloved SII........please help!!!!!!! - Samsung Galaxy S Forums : Galaxy S2 S II Forum - Page 2
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 21
Thread: Very unusual problems with my beloved SII........please help!!!!!!!
  1. #11
    Points: 377, Level: 6
    Level completed: 77%, Points required for next Level: 23
    steve00ie is on a distinguished road
    Kerry, Ireland
    After I acept tyhe T's & C's it clicks into the voice control app and then I just cancelled it out. Seems to bep every so often as well and say the battery is charging when it's not even plugged in!!!
    Kerry, Ireland
    Thanks a lot for that!!! I think there's a chance that might be what was happening! I went into settings and then > motion > motion activation was ticked, a few of the things like double tapping to activate Voice Talk were open, as well as panning etc.
    thanks Pitrack_1!!!!! Fingers crossed!!!!
  4. #13
    Points: 38,555, Level: 86
    Level completed: 29%, Points required for next Level: 645
    The battery charging issue is usually due to a damaged or dirty charging port. Try cleaning the port with an old toothbrush to see if it helps. I also read that someone rubbed a pencil over the battery connections which helped. Has you phone got wet or was it in your pocket when you got caught out in a rainstorm? Sounds like many issues going on here not just one....
  5. #14
    Kerry, Ireland
    Well I do charge it in the car charger which to be honest does look a bit rusty...... as for it getting wet, might have gotten a little wet yesterday alright....
    Thanks so much for the help, it's mad, i spent my whole life avoiding technology and finally got a proper smart phone few months ago...now I don't know what i'd do without !!!!!
    Will let ye know how it works out!
    Thanks from Ireland!!!!!!!!
  6. #15
    Points: 205, Level: 4
    Level completed: 10%, Points required for next Level: 45
    Tagger Second Class7 days registered31 days registered100 Experience PointsTagger First Class
    pitrack_1 is on a distinguished road
    ACT, Australia
    Battery charge indication, beeping, freezing, etc
    Glad to help
    As for the charging when not plugged in, beeping, etc, sounds like you should have a look at this thread:
    My Galaxy S2 has just started draining battery fast
    and in particular at this post by Madddog1974
    A google around may also help by the sounds of things.
    This may be your issue with things. Have you perhaps damaged the bottom of the phone, got it dirty or had trouble with the connector? Sounds like it may be a not-so-strong point with SGSIIs.
    Cheers,
    Pitrack_1
  7. #16
    ACT, Australia
    Quote Originally Posted by Tufftoad View Post
    This option is for taking you to the top of a menu, for example in contacts if you are at the bottom of your contacts, double tap the top of the screen and it will take you to the top.
    Ta Tufftoad, I'm just beginning to learn this stuff! If you've seen my other thread you'll realise I'm technical enough to do a partial hardware lobotomy to save the device but I still am looking up Android acronyms as I read them. Is there a canonical (There, showing my age!!!) thread which lists them somewhere?
    Pitrack_1
  8. #17
    ACT, Australia
    Quote Originally Posted by steve00ie View Post
    Hmmm, Ireland...wet and muddy...or it didn't accidentally have a sip of Murphy's, did it?
    Pitrack_1
  9. #18
    Points: 53,113, Level: 100
    Overall activity: 83.0%
    Quote Originally Posted by pitrack_1 View Post
    lol, no worries. I had to look up canonical, never come across it before.
    I think this is the only thing going at the moment if I understood it right SGS Forum Dictionary
  10. #19
    ACT, Australia
    Thanks, 'tis exactly what I was after!
    Pitrack_1
  11. #20
    Kerry, Ireland
    Thanks for all the help, to be honest Pitrack_1 what you mentioned is exactly what the probglem seems to be! It keeps lighting up and the Vlingo speech keeps running by itself as well as going into car kit mode, as well as not charging enough and then charging by itself!
    So i'll give it a good clean after work! When you say clean the micro USB connector do ya mean the both sides - as in the charger and the actual connection slot in the phone, as well as the battery??? As I said...total novice at this technology buzz...but getting there!!!!
    Thanks for this!!!! Legends!
    Thanks for all the helo!!
