I had voodoo sound on my s but since getting the s3 i'm finding it has a low volume! Is there a decent app to boost it? Avoiding rooting if possible. Thanks
This app works very well, but not fully optimised for ICS, although developer working on it.
https://play.google.com/store/apps/d...cm9pZC5sdmgiXQ..
Im having the same issue. Ive downloaded volume+ as above. Its louder but it sounds horrendous, very tinny. Apparantly a fix is being worked on. Voodoo sound should also be available soon, they already have a prototype.
Glad something's coming out,volume way too low and didn't find vol+ too great either.
