[SGS II] Ring tone - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Results 1 to 10 of 14
Thread: Ring tone
    Points: 28, Level: 1
    Level completed: 56%, Points required for next Level: 22
    Overall activity: 12.0%
    Birdseye is on a distinguished road
    May 2012
    Ring tone
    Hi All,
    Anyone know how to extend the ring tone on galaxy S2?
    Quote Originally Posted by Birdseye View Post
    Hi All,
    Are you wanting to increase the length of time the phone rings or increase the number of available ringtones?
    Points: 2,076, Level: 18
    Level completed: 63%, Points required for next Level: 74
    krizzz is on a distinguished road
    UK Coventry
    If you want it to ring for a longer duration before going to vmail, I believe that's a setting found with your provider...
    Points: 39,916, Level: 87
    Level completed: 80%, Points required for next Level: 184
    **61*destination*nn# [send] where destination = voicemail number & nn = number of seconds (max 30)
    May 2012
    I just want to increase the length of time the phone will ring before going into voice mail.
    May 2012
    There possibly is a setting but I can't find it
    This is normally found in your service provider settings or on their website.
    Do you want voicemail as it can be deactivated.
    Android: How to change ring time for calls before sent to voicemail (AT&T / T-Mobile / GSM Networks)
    Posted by Jimmy Selix in Android
    This tech-recipe will explain how to change the length of time your phone will ring before it sends a call to voicemail. This will only work on GSM based mobile carrier and Android phones (ie AT&T, T-Mobile, any network that uses a SIM Card).
    1.On your Android phone, go to your Phone app and then dial: *#61# and hit Call button.
    This will display your current voicemail number and the delay time. Write down the number since we will need to enter this in next.
    2. On your Android phone, we will go to your Phone app and then the keypad. We will now dial this number from the keypad to change the time your phone will ring before it goes to Voicemail.
    **61*1yyyYYYyyyy*11*xx# and then hit the call button
    So in the above code, you will put your voicemail number where the yYs are and the time delay in seconds for the xx‘s. Once you hit call it will give confirmation if it was successful or not.
    Delay is in five second increments with the maximum being 30 seconds (ie 5,10,15,20,25,30 secs).
    So for example, if my voicemail number is 555-444-4444 and i want to set it to the maximum 30 seconds, i would dial this on my Android phone’s keypad:
    **61*15554445555*11*30#
    This will work for AT&T, T-Mobile, and any other GSM /Sim Card Carrier and may work on other phones besides Android devices.
    May 2012
    Good result, glad I asked. Many thanks.
    Sometimes wonder if I talk to myself..... 8)
