Android phones seem to suffer from one common problem Battery Drain. If you are using an app or have a tip to save battery consumption please post it here. Lets get everyones thoughts into one thread.
Some people that have just recently upgraded to ICS are experiencing short battery life. I myself being one.
My first tip is after installing new firmware is to recalibrate the battery by running the battery flat then recharging it fully without usage. Best do it through the night.
I have installed the following Apps
Juicedefender Ultimate
AutomateIt Pro
These have assisted in saving battery. I will post some rules that I have set up in Automateit later.
Please post your battery saving apps and tips.
