I'm looking for car mount for my SII,I bought one but it doesn't fit because I have a case on it.
It prolly means I'm looking for an adjustable item,any reccomendations?
Thanks.
Thanks.
I know you posted this back in April but as i only joined today, i can only answer now. I had the same issue. I got a window mounted one in Halfords. I think it was about €20. Worked ok in my Focus but when I changed to a Megane I could not find a suitable spot that woked access wise with out it getting to much in mine line of sight. So it now resides in my boot.
I've always used a vent mounted holder as it keeps the phone close to hand.
One I have now came from Woolworths and now fits my S3 so would be ok for S2 + case.
Cheers,I am continuously looking but I discovered that my S2 with the rubber case resides nicely leant up against my dash.
I use two lumps of Blutack with my SGSI9000 on the centre air vents of my Audi S3. The charging lead need tucking in the air vent to take the strain off the connector and stop it slowly pulling the phone round. It was only meant to be a temporary solution but it works so well and looks so neat and flush I've stuck with it - I just keep the two lumps in the ash tray![]()
I've got a headache and eyestrain ... one day all will be fixed!
SGS I9000 with Darky's ROM 9.5 still until they get call recording on a newer ROM
chatter (08-29-2012)
