Battery empty very fast - Samsung Galaxy S Forums : Galaxy S2 S II Forum - Page 2
Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thread: Battery empty very fast
  1. #11
    With using the program and doing every day nearly the same the battery holds about 2 days... could hold longer but at the end i'm using it very much because i don't want to go with a empty battery to work next day...
    i'll try out how long the battery holds without live wallpaper
    fake Mọderator
    Points: 31,311, Level: 77
    Teh USA
    wow 2 days? what kind of stuff are you doing on it?
  4. #13
    Junior Member dotrunghieu is on a distinguished road
    Did you use advanced task killer?
