Latest firmware: static ip and push notifications galaxy S2 - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: Latest firmware: static ip and push notifications galaxy S2
    Points: 502, Level: 8
    Level completed: 2%, Points required for next Level: 98
    Overall activity: 17.0%
    7 days registered31 days registered3 months registeredTagger Second Class100 Experience Points
    stecap is on a distinguished road
    Hello, since I updated the firmware through Kies I cannot set a static ip anymore. I can't find it in the settings!
    Also, I haven't recieved any push notifications anymore, especially from whatsapp. Any suggestions?
    Thank you
    The static IP can be found in Settings > Wifi > now select your connection and you will have a password box (if secured) and underneath two options, one of which is 'advanced'.
    In there is 'static IP'
  4. The Following User Says Thank You to greenman For This Useful Post:
    stecap (04-18-2012)
  5. #3
    Thank you very much, I had to "forget" the network and then it showed up. Any suggestion about the other problem? The system version is 4.0.3
