[How Too] S-II's built-in Clock app's Timer does not sound when going off - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: S-II's built-in Clock app's Timer does not sound when going off
    Points: 412, Level: 7
    Level completed: 12%, Points required for next Level: 88
    7 days registeredTagger Second Class31 days registered100 Experience PointsTagger First Class
    mmo is on a distinguished road
    Since a few weeks I have the very odd effect, that the S-II's built-in Clock app's timer does not ring, when going off. It silently displays "Time's up" on screen, but doesn't sound nor vibrate.
    I do have set a sound in Clock => Timer => Menu => Settings => Alarm Tone and the volume is turned to 100%. I also have set all sounds in Home screen => Menu => Settings => Sound => Volume up to 100% but ther is not sound!
    It drives me nuts and makes the device practically useless as an alert device!
    Any ideas?
    M.
    PS.: I do not have any automatic task killer installed.
    'Since a few weeks ....' is the important part, as it suggests that something you did a few weeks ago has caused this.
    Could be an app/firmware update or other.
    Presumably you've done a soft reboot, so may be time for a factory reset.
    PS Checked on mine and couldn't replicate the problem other than by turning down volume and putting into silent mode on home pull down notification screen.
    Yes - I did a couple of soft reboots since and I also Force stopped the app a couple of times (in Main => Settings => Applications => Manage Applications and also cleared all the app's data trying to "reset" it). If that's not enough then I'll have to look for a new app instead. A factory reset is definitely out of the question!
    M.
    Quote Originally Posted by mmo View Post
    M.
    You've done pretty much all you can, except the factory reset.
    Presumably it's because you have a lot on your phone that you don't wish to risk losing.
    There could be the problem.
    Nothing that could not be restored, but the restore and re-installation of all those apps would take me hours!
    As I said, I'll check for a different clock with timer function. Really odd and annoying, that this doesn't sound any more. And since it is built-in, I can't remove and re-install. There should be a kind of "factory reset this application only"...
    You could remove it if your phone was rooted, but is it worth the effort??
    Like your idea of having a 'restore this application only' except it's often another, unknown, application that creates the conflict and stops the function.
    Exactly the same here! The built-in clock up's Timer doesn't emit any sound but only displays a graphic to drag a circled x left or right.
    Oddly enough, clock alarms do go off with sound, only the timer alerts don't.
    And what really brings me close to factory resetting is, that calendar alerts are also not going off. No indication at all, neither optically nor acoustically. It's driving me nuts!
    BTW: I recently updated from Android 2.3.2 to 4 and that sound bug survived! :-(
    Points: 38,844, Level: 86
    Level completed: 61%, Points required for next Level: 356
    You could put the phone into recovery mode and just do a clear cache first rather than a factory reset. I do, however, suspect it is annother app that is causing the problem.
