Hey bro...i unzipped JVC_JV6_JV3.tar .....this are the files on it....which of them to chose....
You've unzipped too far.
Only do it once.
what to do now?
Hang on I'm downloading the file to see if there is one file or 3.
Have you watched the video on Cnet link I gave?
Have you downloaded Odin from the link on the site?
yes...i saw it step by step...more than 3 times....i downloaded Odin to
If watching the video is a problem take a look at this site. http://forum.xda-developers.com/show....php?t=1075278
Go down to: Flashing Firmware with Odin
You can also download Odin there too.
no its not a problem...its easy...but now i dont know which file to chose
ooooooohhh...i understood now....i ll unzip the downloaded file....then it comes the zip file JVC_JV6_JV3.tar.....thats the file that i have to choose.....not to unzip it
You have just the one file to put in the PDA box.
So select the PDA then look for the file you unzipped ending ORG - this one I9000BVJVC_I9000ORGJV6 ORG
Open and you get JVC_JV6_JV3.
Select and Open and it will appear in the PDA box of Odin.
Now follow the video or XDA link I gave you
wooooooow...thnx man...did it....i wont forget ur help....u r the best......thnx a looooooooot
