Help!!! ICS updated and I have a flashing red border around my screen?! - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Results 1 to 10 of 15
Thread: Help!!! ICS updated and I have a flashing red border around my screen?!
    Points: 748, Level: 10
    Level completed: 48%, Points required for next Level: 52
    As per title..... what have I done LOL.
    Firmware used was I9100XXKP4_I9100OXAKP4 via the sam mobile site.
    I used Odin3 and although the download had 7 files, I only used the CSC, MODEM and code files.
    Can anybody help?
    Jason
    What modes can u get back into.....how does the phone respond?
    I can get into android system recovery and download mode
    But the phone has started playing up bad.... loads of processes crashing and non responding.
    Think I may revert to a hacked ICS version unless I can sort.
    Sorry for basic questions but just narrowing down things.
    The firmware you are using is from December and there is a more recent release for Open Europe. Have you tried flashing the firmware again or you could try I9100XXLPJ? SamMobile.com - GT-i9100 Firmware Europe
    Found this somewhere, does this sound like the problem you are having?
    Q : While using the phone dark red border is coming? How to remove that?
    A : To remove that red border goto settings > Developer options > remove check on Strict mode enabled.
  7. The Following User Says Thank You to Tufftoad For This Useful Post:
    YeTi RaCiNg (03-21-2012)
  8. #5
    No probs at all, the amount I play around with my phone, I should stick to the basics!
    Okay, I'll give that a go with that.
    One question though....
    Obviously from reading the forum I know to steer well clear of playing with .pit files. but if the download has approx 7 files such as Modem, CSC, Phone, A?BOOT etc etc. Should I specifically use just three? or add more for better functionality.
    Jason
  9. #6
    Quote Originally Posted by Tufftoad View Post
    Sorry, missed the edit.
    Will give that a try and advise!
    Am downloading the newer version also.
  10. #7
    strict mode is unchecked, so will definitely try re-flashing
  11. #8
    Hope it works out.
  12. The Following User Says Thank You to Tufftoad For This Useful Post:
    YeTi RaCiNg (03-22-2012)
  13. #9
    It did! Used the rom you linked and it actually took longer to find a copy of Odin than it did to re-flash (at home).
    Only confusion I have now is all the different roms I have located at work and home haha.
    Only downside to the ICS update... Somehow the only app not to have transferred is 'missed it' and I am missing it already.
    Jason
  14. #10
    lol, sounds like a decent app. I know some people have been annoyed that they have missed calls or texts so am posting a link to Google Play - Missed It
  15. Remove Advertisements
