TuneIn Radio Not Compatible With Device - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: TuneIn Radio Not Compatible With Device
    Points: 1,403, Level: 15
    Level completed: 2%, Points required for next Level: 147
    7 days registered500 Experience Points250 Experience Points100 Experience PointsTagger Second Class
    Feb 2011
    My dad showed me TuneIn Radio on his HTC earlier so I thought I'd download it too.
    After locating it through Google, I find that it is not compatible with my phone.
    I have a Samsung Galaxy S.
    Has anyone else had this problem? I can't understand how it can't be compatible.
    Any replies would be great!
    Definitely works on the SGSI, could depend on firmware but doubtful since I've used with custom and stock firmware.
    Forget Android market for TuneIn, on your SGS load up the internet and type in GetJar, go to the website and download the GetJar.apk. GetJar is a market place and is offering TuneIn Pro for Free, allows you to record the radio too.
    Give that a try and see if it works.
    Points: 27,048, Level: 71
    Array Doomed's Avatar
    Yep, I've been using TuneIn Radio to on the SGS.
    Hidden Content
    Feb 2011
    Got it installed with GetJar.
    Thanks for your help Tufftoad!
