kies and pc studio mode question - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Results 1 to 10 of 12
Thread: kies and pc studio mode question
    Points: 2,000, Level: 18
    Level completed: 25%, Points required for next Level: 150
    Overall activity: 16.0%
    Tagger Second Class7 days registered250 Experience Points100 Experience Points3 months registered
    wondered if you could help me, i can't connect to kies, i have sgs2 and everytime i plug in it keeps coming up with (reconnect the device in samsung kies (pc studio) mode, current connection mode not supported) any help to resolve this would be great,
    Hi. Try under Menu > Settings > Wireless & Network > USB Settings.
    I have an SGS1 so my options differ slightly.
    have try'd that, thanks thow
    I'm not sure if this matters but may have read somewhere that it does...but...try ticking or un-ticking USB debugging. Should be under Settings > Applications > Development. Give it a try and if it doesn't work then revert the option to it's original state.
    What PC operating system are you running?
    i have try'd all that aswell, it was working find a few months ago but when i heard that ics was comin i tried to connect and thats how its been, my husbands galaxy note connects ok, i can connect to the computer but not kies, i have the latest kies ,and its a 32bit vista
    Don't use vista much at all, still happy with XP.
    From what I've heard there is an option to connect to Kies via wifi, check under wireless and network settings.
    If you have any compressed air (for cleaning computers) try cleaning the USB port on your device.
    hello i can connect to the computer ok, and can with kies wifi, but not with normal kies, it keeps saying (reconnect the device in samsung kies (pc studio) mode, current connection mode not supported) my hubbys galaxy note and my dads sgs2 both connect ok, its just my bloody phone won't, i've try'd it on to other computers and it still says the same, i know theres the big update soon and i don't want to miss out, any more help will be great before i chuck it in the bin,
    Points: 3,186, Level: 23
    Level completed: 55%, Points required for next Level: 114
    UK Coventry
    Are you using an after market launcher? Do you have the latest version of Kies? Before the latest Kies update I could only connect if I was using the TW stock launcher. So, had to turn of GoLauncher when connecting to Kies.
    Since the update it all works perfectly and my S2 connects first time every time, whatever launcher is selected.
    Vodafone UK
    Points: 2,102, Level: 18
    Level completed: 76%, Points required for next Level: 48
    Array Kev's Avatar
    Northants
    Same here.
    Connects with Wifi mode in Kies every time but USB not a hope, keep getting the exact same message you do know matter what i try.
    SGS II stock out of the Box
    Win 7 64bit
    Need to address this issue for the next Firmware update
    It Would Appear I've Lost My iphone......Again...........Yippi... Hidden Content
    i know its a pain in the a**e i'm on the normall launcher and havn't downloaded anything out of the ordernary, ive been doing alot of research and alot of people have been having the same problem, but can't find a solution, there must be something i can do, ever since i updated kies it hasn't been the same, stupid kies
