Caller Ringtone settings lost! - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: Caller Ringtone settings lost!
    Points: 6,948, Level: 35
    Level completed: 71%, Points required for next Level: 102
    Overall activity: 99.0%
    7 days registeredTagger Second Class31 days registered100 Experience Points3 months registered
    BigIan is on a distinguished road
    Milton Keynes
    After spending ages setting up loads of different caller ring tones, after a few weeks my phone keeps "loosing" them and the callers ring tone reverts back to the general ring tone.
    This has happened on at least six occasions and I'm getting fed up with keep re doing them.
    Has anyone got any idea as to what it might be?
    thanks
    Ian
    Tufftoad has a reputation beyond reputeTufftoad has a reputation beyond reputeTufftoad has a reputation beyond reputeTufftoad has a reputation beyond reputeTufftoad has a reputation beyond reputeTufftoad has a reputation beyond reputeTufftoad has a reputation beyond reputeTufftoad has a reputation beyond reputeTufftoad has a reputation beyond reputeTufftoad has a reputation beyond reputeTufftoad has a reputation beyond repute Tufftoad's Avatar
    Same happens to me, doesn't bother me too much as I only set one ringtone for everyone...still annoying though.
    I will try to find a solution.
    In the meantime you could try using Zedge from the market place, allows you to set ringtones to contacts and may override what is causing the phone to forget ringtones. Try using one ringtone for a while and see if that resets, saves setting them all again.
