Click sound when answering a call - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: Click sound when answering a call
    Points: 35, Level: 1
    Level completed: 70%, Points required for next Level: 15
    Overall activity: 12.0%
    Feb 2012
    I have the i9100 for over a month and already issues occur. One of them, the least annoying, is that when I answer the call and take the phone to the ear, I hear a click sound, something like a relay click when it closes.
    Does this happen to you too?
    Points: 3,186, Level: 23
    Level completed: 55%, Points required for next Level: 114
    UK Coventry
    No................Try going into settings - sound- feedback, untick the three boxes and see if it still happens. I think it might be when your screen turns off via the proximity sensor as you put it to your ear..............Worth a try anyway. Good luck.
