Help fixing application error specific to Galaxy S2 - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: Help fixing application error specific to Galaxy S2
    Points: 68, Level: 1
    Level completed: 36%, Points required for next Level: 32
    Overall activity: 1.0%
    Feb 2012
    All,
    I am a single developer(hobby), and my application (A.S.W.) on the android market has gotten several recent comments that it does not work on the Samsung Galaxy S2. I have been looking for an error in the application, have created an AVD using the S2 spec, but cannot recreate the error. Google Statistics tell me that there are 40+ users with the S2, however, I have gotten no crash/freeze reports from those users. At this point I am stuck and looking for some help to continue troubleshooting the problem, so I have come to this forum in hope of getting some detailed feedback on my applications performance on the S2. You can get the free app by searching the market, or the below link:
    https://market.android.com/details?i...50n.subs&hl=en
    I would appreciate information on:
    Does the application freeze or crash? If so, when did it occur (starting a game, at the title screen, during game play, etc)
    What firmware are you using?
    Do you have any application killer/Battery saver apps running? If yes, does turning it off fix the problem?
    Any other information you believe I may find useful to fix the problem.
    Thanks in advance.
    Greg
    Feb 2012
    Update
    I thought I would give an update on my attempts to isolate the error.
    To date, I have gotten no responses (negative or positive), I guess I can understand why anyone would be leery of downloading and trying this application out for me. No hard feeling here.
    Now, the main reason for this post: For the information of other developers, I did find out that the Samsung developers website has something called Remote Lab, in which you can test your applications on real hardware via a web interface. I was able to test for 30 minutes on the S2 with no issues; however the firmware on the phone was 2.3.3. I am beginning to think it is an issue with a custom/updated firmware, or another application.
    Thank you for taking the time to read this.
    Greg
