[SGS II Rom] Firmware I9100XXLPH Android 4.0.3 (Ice Cream Sandwich) - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Results 1 to 10 of 18
Thread: Firmware I9100XXLPH Android 4.0.3 (Ice Cream Sandwich)
    Points: 27,253, Level: 72
    Level completed: 28%, Points required for next Level: 547
    I9100XXLPH_I9100OXALPH_OXA
    PDA: I9100XXLPH
    PHONE: I9100XXLPH
    CSC: I9100OXALPH
    Build date: February 9 2012.
    Changelist: 118559
    Files inside firmware.
    MODEM_I9100XXLPH_REV_02_CL1104396.tar
    I9100_CODE_I9100XXLPH_CL118559_REV02_user_low_ship .tar
    I9100_APBOOT_I9100XXLPH_CL118559_REV02_user_low_sh ip.tar
    GT-I9100-MULTI-CSC-OXALPH.tar
    How to flash.
    - Open ODIN.
    - Select CODE / MODEM / CSC.
    - Put phone in download mode. (HOME - VOLUMN DOWN - LOCK)
    - Connect phone with cable. Push start (Wait till phone reboot on Android start screen!)
    Changes. (Only more stable in case of LPB)
    Interface: Kind of 3D effect when scrolling.
    Battery: Lot better than early ones.
    Faster: Feels the same as LPB
    Touch: Not so good as LPB.
    Overall: Better score in our eyes than LPB .
    Facelock: Same as LPB working fine.
    Task: Same as version LPB.
    Yes you can use this as daily ROM.
    Fast filehost added!!! Fast, unlimited and parallel download! Premium account is not needed!!!
    ODIN + PIT + Flashguide |Download
    I9100XXLPH|4.0.3|2012 February|CSC - OXX|
    Download from Uploads.ws
    or
    Download from Share-Byte.net
    Root for I9100XXLPH| Download Link1 or Link2
    Screenshots:
  2. The Following 2 Users Say Thank You to BarosanuXXL For This Useful Post:
    jakethesnake (02-17-2012), Sc00by (02-18-2012)
  3. Remove Advertisements
    Points: 1,942, Level: 17
    Level completed: 96%, Points required for next Level: 8
    Overall activity: 32.0%
    Tagger Second Class100 Experience Points7 days registeredTagger First Class31 days registered
    Chesham, UK.
    i am finding that none of the links to the files work.... :-(
  5. #3
    Points: 824, Level: 11
    Level completed: 16%, Points required for next Level: 126
    Overall activity: 12.0%
    Melbourne, Australia
    I got it from Sammobile.
    Points: 5,403, Level: 31
    Level completed: 30%, Points required for next Level: 247
    Overall activity: 99.0%
    7 days registeredTagger Second Class100 Experience Points31 days registered3 months registered
    Array Sc00by's Avatar
    Hampshire, UK
    I've not been too bothered with flashing since I got my S2 - happy with the standard set up etc.
    But now that there is a version of ICS that is supposed to be stable enough for daily use (see GSM Arenas blog - Link below), I'm more than tempted - Thinking about giving this a whirl tonight.
    Has anyone else taken the plunge yet, and have any feedback - or some 2nd hand thoughts ?
    http://blog.gsmarena.com/new-samsung...-benchmark-it/
    Source - GSM Arena
    UPDATE
    Found this thread usefull
    http://androidforums.com/samsung-gal...lpb-xxlph.html
    So gonna go for it, this afternoon
    Galaxy S2, and loving it ;-))
  8. #5
    Points: 101, Level: 2
    Level completed: 2%, Points required for next Level: 49
    7 days registered31 days registeredTagger Second Class100 Experience Points
    Feb 2012
    I have upgraded it and better than LPB.
  9. #6
    Points: 2,172, Level: 19
    Level completed: 11%, Points required for next Level: 178
    Sheffield - Steel City
    Hi all, not flased phone for a long time so sorry for the stupid question.
    What file goes where i odin and also do use the pit file in the odin download to flsh this from 2.3.6.
    Cheers
    SCP
  10. #7
    Hampshire, UK
    I used this thread
    http://forum.xda-developers.com/show....php?t=1420996
    It dates back to the 31st Dec 2011 when ICS was first leaked BUT everything you need is in the very first post as it has been updated.
    The description also relates to the file names in the download so evrything is easy.
    (Just for info, I flashed from Gingerbread to ICS (LPH), using the above XDA files).
    Having said that, I might have used the PIT file from the download in the first post of this thread ?
  11. The Following User Says Thank You to Sc00by For This Useful Post:
    SCP (02-19-2012)
  12. #8
    Thanks for that sc00by done it now ad am impressed, only thing i dont like s that i am on virgin mobile but sgs2 now shoing it as t-mobile lol
  13. #9
    Feb 2012
    Battery: Not better than early ones.
    I have test and empty battery about 1,5 days, the older version is >=2days
  14. #10
    Points: 140, Level: 2
    Level completed: 80%, Points required for next Level: 10
    7 days registered31 days registered100 Experience Points
    Feb 2012
    Hi
    I flashed the XXLPH firmware and its good, but sometimes my apps do stop working but nothing major and the battery is about 1 and half days.
    Does anyone know if you can get the Orange Signal Booster to work on ICS ???
    have been searching forums without any luck
    any help would be great
  15. Remove Advertisements
