Samsung Galaxy Note Secret Codes - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: Samsung Galaxy Note Secret Codes
    Administrator Briggs has a brilliant future Briggs has a brilliant future Briggs has a brilliant future Briggs has a brilliant future Briggs has a brilliant future Briggs has a brilliant future Briggs has a brilliant future Briggs has a brilliant future Briggs has a brilliant future Briggs has a brilliant future Briggs has a brilliant future Briggs's Avatar
    Spain
    Here are some standard secret codes that work on the Galaxy Note. They are basically the same codes as the SGS II. If you find any new ones please add them.
    Use caution when using some of these codes. We're not responsible if you some how manage to damage or mess up your Note
    *#06# = IMEI Number.
    *#1234# = Firmware Version.
    *#2222# = H/W Version.
    *#8999*8376263# = All Versions Together.
    *#8999*8378# = Test Menu.
    *#4777*8665# = GPSR Tool.
    *#8999*523# = LCD Brightness.
    *#8999*377# = Error Menu.
    *#8999*327# = EEP Menu.
    *#8999*667# = Debug Mode.
    *#92782# = PhoneModel. (Wap)
    #*5737425# = JAVA Mode.
    *#2255# = Call List.
    *#232337# = Bluetooth MAC Adress.
    *#5282837# = Java Version.
    #*4773# = Incremental Redundancy.
    #*7752# = 8 PSK uplink capability bit.
    #*7785# = Reset wakeup & RTK timer cariables/variables.
    #*7200# = Tone Generator Mute.
    #*3888# = BLUETOOTH Test mode.
    #*7828# = Task screen.
    #*#8377466# = S/W Version & H/W Version.
    #*2562# = Restarts Phone.
    #*2565# = No Blocking? General Defense.
    #*3353# = General Defense, Code Erased.
    #*3837# = Phone Hangs on White screen.
    #*3849# = Restarts Phone.
    #*3851# = Restarts Phone.
    #*3876# = Restarts Phone.
    #*7222# = Operation Typ: (Class C GSM)
    #*7224# = !!! ERROR !!!
    #*7252# = Operation Typ: (Class B GPRS)
    #*7271# = CMD: (Not Available)
    #*7274# = CMD: (Not Available)
    #*7337# = Restarts Phone. (Resets Wap Settings)
    #*2787# = CRTP ON/OFF.
    #*2886# = AutoAnswer ON/OFF.
    #*3737# = L1 AFC.
    #*5133# = L1 HO Data.
    #*7288# = GPRS Detached/Attached.
    #*7287# = GPRS Attached.
    #*7666# = White Screen.
    #*7693# = Sleep Deactivate/Activate.
    #*7284# = L1 HO Data.
    #*2256# = Calibration info? (For CMD set DEBUGAUTONOMY in cihard.opt)
    #*2286# = Databattery.
    #*2527# = GPRS switching set to (Class 4, 8, 9, 10)
    #*2679# = Copycat feature Activa/Deactivate.
    #*3940# = External looptest 9600 bps.
    #*4263# = Handsfree mode Activate/Deactivate.
    #*4700# = Please use function 2637.
    #*7352# = BVMC Reg value (LOW_SWTOFF, NOMINAL_SWTOFF)
    #*2558# = Time ON.
    #*3370# = Same as 4700.
    #*3941# = External looptest 115200 bps
    #*5176# = L1 Sleep.
    #*7462# = SIM Phase.
    #*7983# = Voltage/Freq.
    #*7986# = Voltage.
    #*8466# = Old Time.
    #*2255# = Call Failed.
    #*5187# = L1C2G trace Activate/Deactivate.
    #*5376# = DELETE ALL SMS!!!!.
    #*6837# = Official Software Version: (0003000016000702)
    #*7524# = KCGPRS: (FF FF FF FF FF FF FF FF 07)
    #*7562# = LOCI GPRS: (FF FF FF FF FF FF FF FF FF FF FF FE FF 01)
    #*2337# = Permanent Registration Beep.
    #*2474# = Charging Duration.
    #*2834# = Audio Path. (Handsfree)
    #*3270# = DCS Support Activate/Deactivate.
    #*3282# = Data Activate/Deactivate.
    #*3476# = EGSM Activate/Deactivate.
    #*3676# = FORMAT FLASH VOLUME!!!
    #*4760# = GSM Activate/Deactivate.
    #*4864# = White Screen.
    #*5171# = L1P1.
    #*5172# = L1P2.
    #*5173# = L1P3.
    #*7326# = Accessory.
    #*7683# = Sleep variable.
    #*8465# = Time in L1.
    #*2252# = Current CAL.
    #*2836# = AVDDSS Management Activate/Deactivate.
    #*3877# = Dump of SPY trace.
    #*7728# = RSAV.
    #*2677# = Same as 4700.
    #*3728# = Time 2 Decod.
    #*3725# = B4 last off.
    #*7372# = Resetting the time to DPB variables.
    #*7732# = Packet flow context bit Activate/Deactivate.
    #*6833# = New uplink establishment Activate/Deactivate.
    #*3273# = EGPRS multislot. (Class 4, 8, 9, 10)
    #*7722# = RLC bitmap compression Activate/Deactivate.
    #*2351# = Blinks 1347E201 in RED.
    #*4472# = Hysteresis of serving cell: 3 dB
    #*2775# = Switch to 2 inner speaker.
    #*9270# = Force WBS.
    #*7878# = FirstStartup. (0=NO, 1=YES)
    #*3757# = DSL UART speed set to. (LOW, HIGH)
    #*8726# = Switches USBACM to Normal.
    #*8724# = Switches USBACM to Generator mode.
    #*8727# = Switches USBACM to Slink mode.
    #*8725# = Switches USBACM to Loop-back mode.
    #*3838# = Blinks 3D030300 in RED.
    #*2077# = GPRS Switch.
    #*2027# = GPRS Switch.
    #*0227# = GPRS Switch.
    #*0277# = GPRS Switch.
    #*8370# = Tfs4.0 Test 0.
    #*8371# = Tfs4.0 Test 1.
    #*8372# = Tfs4.0 Test 2.
    #*8373# = Tfs4.0 Test 3.
    #*8374# = Tfs4.0 Test 4.
    #*8375# = Tfs4.0 Test 5.
    #*8376# = Tfs4.0 Test 6.
    #*8377# = Tfs4.0 Test 7.
    #*8378# = Tfs4.0 Test 8.
    #*8379# = Tfs4.0 Test 9.
    #*22671# = AMR REC START.
    #*22672# = Stop AMR REC. (File name: /a/multimedia/sounds/voice list/ENGMODE.amr)
    #*22673# = Pause REC.
    #*22674# = Resume REC.
    #*22675# = AMR Playback.
    #*22676# = AMR Stop Play.
    #*22677# = Pause Play.
    #*22678# = Resume Play.
    #*77261# = PCM Rec Req.
    #*77262# = Stop PCM Rec.
    #*77263# = PCM Playback.
    #*77264# = PCM Stop Play.
    #*22679# = AMR Get Time.
    *#8999*364# = Watchdog ON/OFF.
    *#8999*427# = WATCHDOG signal route setup.
    *2767*226372# = Camera Reset. (deletes photos)
    *2767*3855# = E2P Full Reset.
    *2767*2878# = E2P Custom Reset.
    *2767*927# = E2P Wap Reset.
    *2767*226372# = E2P Camera Reset.
    *2767*688# = Reset Mobile TV.
    #7263867# = RAM Dump. (On or Off)
    * # 06 # Show IMEI number
    * # 0 * # LCD Test Menu
    * # * # 4636 # * # * user statistics and Phone Info
    * # 0011 # Displays status information for the GSM
    *#1234# View SW Version PDA, CSC, MODEM
    *#12580*369# SW & HW Info
    *#197328640# Service Mode
    *#0228# ADC Reading
    *#32489# (Ciphering Info)
    *#232337# Bluetooth Address
    *#232331# Bluetooth Test Mode
    *#232338# WLAN MAC Address
    *#232339# WLAN Test Mode
    *#0842# Vibra Motor Test Mode
    *#0782# Real Time Clock Test
    *#0673# Audio Test Mode
    *#0*# General Test Mode
    *#2263# RF Band Selection
    *#9090# Diagnostic ConfiguratioN
    *#7284# USB I2C Mode Control
    *#872564# USB Logging Control
    *#4238378# GCF Configuration
    *#0283# Audio Loopback Control
    *#1575# GPS Control Menu
    *#3214789650# LBS Test Mode
    *#745# RIL Dump Menu
    *#746# Debug Dump Menu
    *#9900# System Dump Mode
    *#44336# Sofware Version Info
    *#7780# Factory Reset
    *2767*3855# Full Factory Reset
    *#0289# Melody Test Mode
    *#2663# TSP / TSK firmware update
    *#03# NAND Flash S/N
    *#0589# Light Sensor Test Mode
    *#0588# Proximity Sensor Test Mode
    *#273283*255*3282*# Data Create Menu
    *#273283*255*663282*# Data Create SD Card
    *#3282*727336*# Data Usage Status
    *#7594# Remap Shutdown to End Call TSK
    *#34971539# Camera Firmware Update
    *#526# WLAN Engineering Mode
    *#528# WLAN Engineering Mode
    *#7412365# Camera Firmware Menu
    *#07# Test History
    *#3214789# GCF Mode Status
    *#272886# Auto Answer Selection
    *#8736364# OTA Update Menu
    *#301279# HSDPA/HSUPA Control Menu
    *#7353# Quick Test Menu
    *2767*4387264636# Sellout SMS / PCODE view
    *#7465625# View Phone Lock Status
    *7465625*638*# Configure Network Lock MCC/MNC
    #7465625*638*# Insert Network Lock Keycode
    *7465625*782*# Configure Network Lock NSP
    #7465625*782*# Insert Partitial Network Lock Keycode
    *7465625*77*# Insert Network Lock Keycode SP
    #7465625*77*# Insert Operator Lock Keycode
    *7465625*27*# Insert Network Lock Keycode NSP/CP
    #7465625*27*# Insert Content Provider Keycode
    *#272*imei#* Product code , works on Froyo
    *#*#7780#*#* Factory data reset - Clears Google-account data, system and program settings and installed programs. system will not be deleted, and OEM programs, as well as My Documents (pictures, music, videos)
    My IP address | LG Optimus G Pro Forum
    Points: 193, Level: 3
    Level completed: 86%, Points required for next Level: 7
    Tagger Second Class7 days registered31 days registered100 Experience Points
    kersy is on a distinguished road
    that is some deadly data
There are currently 2 users browsing this thread. (0 members and 2 guests)
