Hi Folks...........I bought the Samsung larger capacity battery + cover. Can anybody tell me where I can buy a case that fits this due to the extra thickness.
I tried Samsung customer support but were as much good as a chocolate watch.
i used to have the same problem and did a lot of searching and found nothing i have now gone back to using the slim battery
I take it is the 3500mAh one or 2700mAh you bought?
If so, no such case exists dude unfortunately. I made one out of an existing one I had so it had protection around part of the back and sides, but thats about the best you can hope for.
For the best battery, I would recommend the 1800mAh, this fits in the I9000, although made for the Galaxy S2 Epic in USA, fits our phones fine :-) and you can put the existing cases on for it.
Hacked; Xbox 360, PSP, PS2/3, Nintendo DS/Wii, ZTE Blade, Motorola Xoom, Sony Xperia, Viewsonic M900S, HTC Desire/Desire HD/Sensation, Samsung Galaxy SI/SII/SIII
I bought the samsung extended battery and it came with a new back which takes the thicker battery.
