[SGS II Rom] Firmware I9100XXLP2 Android 4.0.3 (Ice Cream Sandwich) for Samsung Galaxy S II I9100 - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 29
Thread: Firmware I9100XXLP2 Android 4.0.3 (Ice Cream Sandwich) for Samsung Galaxy S II I9100
    Points: 12,521, Level: 48
    Level completed: 45%, Points required for next Level: 279
    BarosanuXXL has a spectacular aura about BarosanuXXL has a spectacular aura about BarosanuXXL has a spectacular aura about
    I9100XXLP2_I9100OXALP2_OXA
    PDA: I9100XXLP2
    PHONE: I9100XXLP1
    CSC: I9100OXALP2
    Build date: January 10 2012.
    Changelist: 57619
    How to flash.
    - Open ODIN.
    - Select CODE / MODEM / CSC.
    - Put phone in download mode. (HOME - VOLUMN DOWN - LOCK)
    - Connect phone with cable. Push start (Wait till phone reboot on Android start screen!)
    Changes.
    Interface: Nothing in case of XXLP1.
    Battery: Battery feels better.
    Faster: Phones looks faster.
    Touch: Touch response is better.
    Overall: Firmware more stable but still with some bugs.
    Facelock: Working.
    Task: Task maneger is back.
    ODIN + PIT + Flashguide | DOWNLOAD Link1 or Link2
    I9100XXLP2|4.0.3|2012 January|CSC - OXA| DOWNLOAD Link1 or Link2
    Root for I9100XXLP2| Download Link1 or Link2
    Screenshot:
    Points: 198, Level: 3
    Level completed: 96%, Points required for next Level: 2
    greenman is on a distinguished road
    This is a MUCH better version and I would say suitable for everyday use.
    The menu and return button light has returned, and generally runs a lot smoother with better battery life.
    NOTE: The binary counter and triangle are not removed via the USB Jig as the bootloader has been updated to prevent this.
    Intratech came up with workaround here and says:
    'I've attached the old bootloader repackaged in a tarball for Odin. Anyone who's flashed the full firmware package and cannot reset their binary counter with a USB Jig, Flash this with Odin and then try the Jig.
    Place tarball in the PDA section of Odin'
    EDIT: Sorry the previous link didn't work. try this one:
    http://www.multiupload.com/LQQBRQVJUD
    Points: 464, Level: 7
    Level completed: 64%, Points required for next Level: 36
    Overall activity: 60.0%
    Tagger Second Class100 Experience Points7 days registeredTagger First Class31 days registered
    sferg.410 is on a distinguished road
    the linke does not work...
    as for KLP2, it is not on here. Surely XXLP2 (this thread) is the latest release????
    Points: 333, Level: 6
    Level completed: 33%, Points required for next Level: 67
    Overall activity: 10.0%
    Tagger Second ClassTagger First Class100 Experience Points7 days registered250 Experience Points
    Dusty605 is on a distinguished road
    Hi being new to all this I have just unzipped the file and haven't got a clue what bit goes where in odin. I am at work now and pc is at home so can't tell you what files they are but there seems to be more files than boxes on odin. Please help as it confuses the hell out of me. If you have the files unzipped yourself in hope you'll understand what I mean. Thanx, dusty
    thing is dusty, if you really know that little maybe you should not mess with your phone until you have done a little more research and learning...???
    Quote Originally Posted by sferg.410 View Post
    Cool thanx for that but isn't that what I'm doing, researching, gotta start somewhere we weren't all born computer whizzes. I have successfully flashed stick firmware via odin and rooted so for me this is the next stage.
    Agree with you Dusty605. What better way to learn about your phone than to 'do' something with it.
    Anyway to answer your question regarding Odin and files:
    The information is all in the opening message, but this guide with screenshots will probably help:
    http://androidflip.com/how-to-instal...-s-2-gt-i9100/
    Once you've done this, rooting is easy and gives you more control over your S2.
    Go to Chainfire's site on XDA developers and find the root file closest to your firmware: http://forum.xda-developers.com/show....php?t=1103399
    Thanks Greenman, it is all good now, thanks a lot.
    Now running ICS 4.0.3 XXLP2, fully rooted, no yellow triangle and 0 on the download screen counter, after buying a jig for £2 on ebay last week which didnt work until Greenman's file, thanks again.
    Points: 98, Level: 1
    Overall activity: 2.0%
    7 days registered31 days registered
    Bone03 is on a distinguished road
    Hi... For those who are already using this verision, has anyone tried to use the Email App? My SGSII is already running ICS 4.0.3 XXLP2 and when I tried to set-up my Emails on the Email App, it always says "Connection Error". I tried to run other Apps like Skype and Gmai, also tried downloading games from Market to make sure my Wi-Fi is connected and I did not have any problem connecting.
    Thanks...
    I had the same problem with emails so went back to 2.3.6 as I like my emails on my phone.. Other than that I didn't encounter any major problems.
