problems with charging battery in new galaxy s2 - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: problems with charging battery in new galaxy s2
    Points: 31, Level: 1
    Level completed: 62%, Points required for next Level: 19
    Overall activity: 1.0%
    Having big problems charge my battery on the Samsung galaxy sII it seem to be discharging the battery and not charging I brought an extra battery charge it run the phone for 12 hrs plug it in and nothing it says it charge it but not after 15 hrs on charge nothing is in the battery please help
    If neither battery is charging it could be a couple of things:
    1) The micro usb port could be dirty or damaged
    2) The cable/charger that you are using could be faulty
    Try using a different cable to charge the phone, you should have a mains plug charger and a usb cable. If neither of them work then it's a problem with the device.
