Help ! phone thinks it is unlocked but isn't - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Results 1 to 7 of 7
Thread: Help ! phone thinks it is unlocked but isn't
    Points: 1,598, Level: 16
    Level completed: 24%, Points required for next Level: 152
    7 days registeredTagger Second Class31 days registered100 Experience Points250 Experience Points
    Couchwarrior is on a distinguished road
    Feb 2011
    Got a UK sgs2 on 3 yesterday, but I needed it unlocked for Orange
    First thing was to root the phone, its on K18 and 235 no problems there
    Tried galaxy s2 sim unlock and no codes found
    Tried Galaxy S unlock and all that did was remove prompt for code
    restored saved EFS
    Paid £15 to a mobile unlocking company, code worked for approx 2 minutes and now no prompt for code again, 3 sim still works, luckily I have a saved EFS so can get back to the code unlock screen if needed. Have now done it about a thousand times lol
    when i put in *#7465625* it says everything is off next bit of confusion I tried a tesco sim in it and it works with that but not Orange, tried 2 Orange sims just in case
    Found these #7465625*638*CODE# (or *#7465625*638*CODE#) or #0111*CODE# and none of them worked
    I do have an unfeeze code as well, I was considering freezing the phone on purpose then unlocking it but I am scared that it doesn't work
    Feb 2011
    just tried an o2 sim and that also works
    Points: 30,583, Level: 76
    Level completed: 67%, Points required for next Level: 267
    Overall activity: 63.0%
    Goots has a reputation beyond repute Goots has a reputation beyond repute Goots has a reputation beyond repute Goots has a reputation beyond repute Goots has a reputation beyond repute Goots has a reputation beyond repute Goots has a reputation beyond repute Goots has a reputation beyond repute Goots has a reputation beyond repute Goots has a reputation beyond repute Goots has a reputation beyond repute Goots's Avatar
    Seems like Orange are doing something non-standard with their SIMs? (And I wouldn't put it past them tbh)
    Galaxy S GT-I9000 Cyanogenmod Android v4.2.2 JellyBean Twitter : 1969guy Circle me on Google+
    Points: 20,696, Level: 62
    Level completed: 77%, Points required for next Level: 154
    Overall activity: 99.7%
    Quote Originally Posted by Goots View Post
    If this is true, then T-Mobile won't be far behind.
    Feb 2011
    just tried an orange payg and that doesnt work either, haven't got access to a tmobile so cant try that
    Feb 2011
    any thoughts on freezing it on purpose ?
    Feb 2011
    reply from mobileunlocked.com
    It is not possible for a phone to be locked AWAY from a network, only TO a network.
    Your phone is not network locked, and that is definitely clear because it works on several different networks.
    Whether Orange have a specific block on the phone, or the Orange SIM cards are faulty, or something else is wrong altogether is not something we can detect remotely. I would strongly suggest you call Orange and ask them, being sure to explain that the phone does work on both O2 and Three.
