Phone cannot make or receive calls and texts!! Please help! - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: Phone cannot make or receive calls and texts!! Please help!
    Points: 54, Level: 1
    Level completed: 8%, Points required for next Level: 46
    Overall activity: 32.0%
    Angry Phone cannot make or receive calls and texts!! Please help!
    Hi, I'm having a problem with my Galaxy S I9000, it stops receiving calls, they go straight to voice mail and when I try to call, it hangs up on its own! The same thing with texts..until I turn the phone off and then on or turn flight mode on and then off ..then I could make calls..It's not a network problem because I tried my sim card in an other phone for two days and it's fine and the signal is great where I live..I'm sure the problem is in the phone because I've been having this problem for two weeks...My phone is not rooted and I didn't update anything...please help!
    Points: 27,048, Level: 71
    Array Doomed's Avatar
    Try a factory reset, or better - update the phones software More info around the forum.
    Type: *#1234# into your phone to show what firmware you are on.
    Hidden Content
    Tried the factory reset but I still have the same problem I'll try the update thing hope it'll work thanks
    Points: 80, Level: 1
    Level completed: 60%, Points required for next Level: 20
    Tagger Second Class7 days registered31 days registered
    Install a custom rom and see if that resolves the issue. Or reinstall the latest official samsung firmware via ODIN procedure.
    Quote Originally Posted by didier View Post
    What's a custom ROM?
    This is what I get When I enter the code *#1234#
    PDA: I9000XWJVH
    PHONE: I9000XXJVO
    CSC: I9000XEFJV2
    Can you help me guys, I'm new to these things could you please show me how to update the phone?
