Please help! keeps sayin insert sim card! - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: Please help! keeps sayin insert sim card!
    Points: 25, Level: 1
    Level completed: 49%, Points required for next Level: 25
    Exclamation Please help! keeps sayin insert sim card!
    hi ive had my samsung galaxy s2 for about 4 months now, ive had no problems with it but all of a sudden over the last few days it keeps telling me to insert a sim card even though my simcards already in, ive tried cleaning the sim card an the slot, using different simcards, factory reset but nothing has sorted it.
    You need to try putting another sim in the phone and see if that works. If you don't have a sim then take it to a phone shop and see if they will try.
    edit: If the another sim doesn't work then more than likely you have a problem with the sim connection.
    ive tried a number of sim cards for different networks an still doesnt work :\
    Points: 4,129, Level: 27
    Level completed: 10%, Points required for next Level: 271
    Overall activity: 9.0%
    7 days registered31 days registered100 Experience PointsTagger Second Class250 Experience Points
    Bangalora, India
    Could be two reasons:
    1. All inserted sim were not functional
    2. sim card slot not functioning properly
    Solutions:
    1. insert sim card through which you can make call and receive call.
    2. go to service center to get it resolved
