read nfc tags - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: read nfc tags
    Points: 1,665, Level: 16
    Level completed: 58%, Points required for next Level: 85
    Overall activity: 10.0%
    Tagger Second Class100 Experience PointsTagger First Class7 days registered250 Experience Points
    okeee is on a distinguished road
    read nfc tags
    how do i check if the phone can read nfc tags? or how do i even turn it on, or scan nfc tags? i couldnt find anything in the manual.
    ROM Modder
    Points: 2,494, Level: 20
    Level completed: 72%, Points required for next Level: 56
    Overall activity: 56.0%
    DSA is a jewel in the rough DSA is a jewel in the rough DSA is a jewel in the rough DSA's Avatar
    Where is your phone from? Only certain models have nfc integrated
    Points: 4,129, Level: 27
    Level completed: 10%, Points required for next Level: 271
    Overall activity: 9.0%
    7 days registered31 days registered100 Experience PointsTagger Second Class250 Experience Points
    shuk is on a distinguished road
    Bangalora, India
    Just download "z-Device test" apps from market and run it. It will shoe all apps present at your device.
    the phone is from netherlands, but the model was for spain?
    and what i want to know, how do i scan nfc tags, how does it work?
    I doubt a european model has got nfc.
    how do i check if it can read nfc?
    Look on the box it came in and see if it says it? Or try and use the nfc somewhere, which I doubt you are going to do very much if you don't even know how to.
    Bangalora, India
    Whatever model you have either from netherland or form sapin "z-Device test" apps will show it whether you have nfc or not.
