why is my pc not reading my phone when i connect thru usb - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Results 1 to 10 of 11
Thread: why is my pc not reading my phone when i connect thru usb
    Points: 21, Level: 1
    Level completed: 41%, Points required for next Level: 29
    when i bought the samsung galaxy s2 on friday, i tried to connect it to my computer using the usb and it started to read it, but then i received an error message on one of the 5 parts it was trying to read. since then i have not been able to connect the phone to the computer.. what is going on?
    Points: 1,793, Level: 17
    Level completed: 22%, Points required for next Level: 157
    7 days registered31 days registeredTagger Second Class100 Experience Points250 Experience Points
    Were you trying to connect through Kies, or as USB storage?
    Points: 3,419, Level: 24
    Level completed: 48%, Points required for next Level: 131
    Tagger Second ClassTagger First Class7 days registered100 Experience Points250 Experience Points
    Quote Originally Posted by blooeyes13 View Post
    Connectng to PC you need dedicated program for it. Samsung provides Kies. With Kies you can connect manually by initiating it from you PC (you have to download and install it to you PC) or using Kies Air initiated from your device to get url address and open it with internet explorer by entering the url address.
    You can also using third party program MyPhoneExplorer (search it with Googleor Yahoo search engine).
    As what I do know, USB direct connection won't work on Android phones, so you have to connect it via WiFi.
    Points: 40, Level: 1
    Level completed: 80%, Points required for next Level: 10
    7 days registered
    in settings/applications/development untick usb debug (first option). After that your pc will connect in usb mode and you will see your phone in my computer.
    I am using another language in my phone so I don't know what exacly locks like in your. Sorry.
    Points: 2,671, Level: 21
    Level completed: 49%, Points required for next Level: 129
    Array jimc130's Avatar
    Dec 2010
    Quote Originally Posted by oly730 View Post
    What are you talking about...USB direct connection wont work...of course it does, and a simple "google it" will give you an answer.
    SGS I9000
    Rom: Teamhacksung's ICS Port for Galaxy S
    Android 4.0.3
    Points: 214, Level: 4
    Level completed: 28%, Points required for next Level: 36
    Overall activity: 31.0%
    7 days registeredTagger Second Class100 Experience Points31 days registeredTagger First Class
    NY, USA
    USB direct connection works fine, you don't know what your talking about. I use it every day.
    NY, USA
    What was the error message? Which direction were you copying? Were you going to/from the sdcard?
    You really do not know what you are talking about. You must be referring to iPhones or what use to be the problem with Windows mobile.
    What do you mean by "one of the 5 parts"? Are you referring to the metal strips on the USB connector?
    Try using another USB cable if you can.
    Also check your settings Menu > Settings > Wireless & Network > USB :This should be the options but I only have an SGS1.
    Also read my thread on different ways to transfer media between your device and the PC.
    Points: 721, Level: 10
    Level completed: 21%, Points required for next Level: 79
    7 days registeredTagger Second Class100 Experience Points31 days registered3 months registered
    Skip the USB cable entirely, use AirDroid, free from the app market. I heard about it from the thread below. Awesome, much cleaner than Kies and entirely wireless.
    http://samsunggalaxysforums.com/show...eplacement-app
    Points: 40,034, Level: 87
    Array Goots's Avatar
    Sorry, but lol at this
