I'm having the same problem, it just stopped working all of a sudden, I have tried many things without luck. Anyone having this issues? what could be a possible solution?
If it's stopped working all of a sudden then it's highly likely that it'll start working all of a sudden.
Can you achieve what you need to achieve in a different way? What are trying to do?
Try different USB ports or try a different cable?
My USB link also suddenly stopped.
Try the solution posted here:-
http://samsunggalaxysforums.com/show...-with-S2/page2
Out of curiosity I tried it again whilst writing this msg. It was a struggle. I first forgot to close down all other apps on the S2. I have a Task Manager on my home screen to check that. I then turned off Power Saving and Screen blanking. I then start Keis and pop the S2 into the desk caddy making sure it is not locked. The PC saw the linked S2 within about ten secs and Keis a few seconds after.
It would help if you tell us whether you did and whether it works, please.
Tony
Hi, I am newbie to both Samsung phone and Android. I just got S2 and try to connect to my laptop. I downloaded driver and Kies and rebooted but still couldn't recognize the phone by the lap top (neither by USB or kies) . Just keep trying conecting.....
Please advise what should I do? Thx,
"Please advise what should I do?"
Read my message and then tell us where you get stuck. That is why we offer advice. We can't help you at all from what you have just posted.
Tony
Hi. I too had the connection problem, but a hard reset fixed it.
Kevin
Aftab,
Have you tried a hard reset?
Tony
ON YOUR S2 OPEN THE DIALER AN TYPE IN....
*#7284#
you will see ...
UART
MODEM
PDA
USB
MODEM
PDA
UNDER USB (if it already selected) to PDA Click MODEM then RESELECT (CLICK) PDA
ONLY repeat "ONLY" Change the USB SETTING
Then press Back. Now try connecting via USB............Should Work.....
