Samsung Galaxy S2 Question: Whats the difference between USB storage memory & SD card - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: Samsung Galaxy S2 Question: Whats the difference between USB storage memory & SD card
    Points: 120, Level: 2
    Level completed: 40%, Points required for next Level: 30
    Tagger Second Class7 days registeredTagger First Class100 Experience Points
    peterdan1506 is on a distinguished road
    When i go install apps 2 the SD on my device AND download the game data 2 my SD card, it still saves 2 the USB Storage memory and in settings under storage i have USB Storage Memory and SD Card memory... Shouldnt the games/apps install on the SD Card and not the USB Memory??
    Even in file manager it says sdcard.... then it says external SD... im confused... plz help someone 10 points for best answer.
    Points: 89,119, Level: 100
    Tufftoad has a reputation beyond reputeTufftoad has a reputation beyond reputeTufftoad has a reputation beyond reputeTufftoad has a reputation beyond reputeTufftoad has a reputation beyond reputeTufftoad has a reputation beyond reputeTufftoad has a reputation beyond reputeTufftoad has a reputation beyond reputeTufftoad has a reputation beyond reputeTufftoad has a reputation beyond reputeTufftoad has a reputation beyond repute Tufftoad's Avatar
    Quote Originally Posted by peterdan1506 View Post
    I responded to your last post.
    On an SGSI (8Gb)
    2GB is for ROM
    The SD Card is you internal storage (6GB)
    The external SD card is your external storage.
    Viewing the directory structure using an explorer:
    /system/sdcard/ = Internal storage (6Gb)
    system//sdcard/externalsd/ = External Storage
    /system/ = 2GB ROM
