Echo - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: Echo
    Points: 125, Level: 2
    Level completed: 50%, Points required for next Level: 25
    Overall activity: 40.0%
    Tagger Second Class7 days registeredTagger First Class100 Experience Points
    chicoelnino is on a distinguished road
    Echo
    I've villain Rom 3.0 flashed on m s2.
    I've bad echo on voice calls my friends tell me whenever they ring.... As in they can hear there own echo. everything is ok my end.
    I installed villaintweaks 1.3.1 as I was told there was a fix fire this. I installed the noise cancellation fix.... But still it remained. Anyone any suggestions?
    Really would like to get this echo. I don't like having to keep pressing menu-noise reduction off during every call.
    Also notice that if I remove my protective case the echo disappears completely....but I don't want to leave the phone unprotected.
    Also, is it possible to fully remove villaintweaks and all of its data(and tweaks that I installed) from the phone? Would a normal uninstall work, or would I have to do something else.
    Any help would be great!
    Points: 3,509, Level: 24
    Level completed: 84%, Points required for next Level: 41
    Overall activity: 10.0%
    Tagger Second Class7 days registered31 days registered100 Experience Points3 months registered
    clax6 will become famous soon enough
    I think its the case
